Do I have everything I need?
tygray6
Ok so next weekend i'm attempting the install of a Pioneer AVIC Z150BH in my 07 GMC Yukon, I just want to make sure i'm all set with the harnesses and parts I need. Here is what I have so far.
-Pioneer ND-BC5 Universal Rearview Camera
-Metra 95-3305 Double DIN Installation Dash Kit for 2006-up Chevrolet Vehicles
-Parking Brake Override Bypass Fully Automatic Video in Motion Pioneer Extra Wire with OEM Pin and Tool Kit
-Stereo ANTENNA Harness GMC Yukon 07 2007
-Pac Rp4-gm31 Radiopro4 Interface
Basically i'm worried that this last entry here is the harness I need or is it just the harness for the door chimes, and steering wheel controls?
jebt2921
AR
There is a new RadioPro5 out now that might be better. I'm looking to do this same setup and might go with the Metra Axxess ADGM100. From what I've read the Pac interface can be a bit buggy and the Axxess module retains your factory door chimes as well.
If you have factory reverse camera you just need the adapter from Metra to plug it into the Pioneer unit. I've got an 08 Hybrid Tahoe and I'm probably going to do an onstar/bluetooth VCIM swap before I upgrade to this Pioneer unit so I can retain the factory bluetooth function and use the Onstar mic since it's way better then using one of those afermarket mics you typically install on the visor.... I'm wanting to retain every OEM feature I've got (bluetooth, sirius, onstar, door chimes, reverse sensors, back-up camera, 2nd row DVD entertainment, BOSE, steering wheel controls, etc.
Keep up posted on how the install goes and exactly what OEM features you're wanting to retain.
T
tygray6
well i've already got the pac module at home which I purchased online so i'm gonna give it a try just because of the hassle of return, are there any VCIM swap guides that can help me use my mic for my new radio when I get it installed?
Tenn2033
