Do TPMS need to be reset when rotating tires?
HiHoeSilver
Away!
Chicago
04 should report locations on the DIC. if you scroll through the options in the odometer button, you will get to "tire pressures" push the enter button and it will scroll through each tire and its pressure reading.
MidwestMike
Southwest Michigan
Any idea how a 2014 should work? Should you need the tool to relearn the tire location, or should the "let the air out" method work?
I was able to get mine to the "let the air out" programming phase, but could not get any results when deflating the tire.
tony97218
