LAST FALL FINISHED TWO AREAS ON MY '99. ONE WAS A TRIBLE PANEL INTERSECTION--TOUGH AREA TO FAB FROM SCRATCH, SO USED KBS COATINGS PRODUCTS TO TRY TO KILL THE RUST. JOB MIGHT LAST, BUT, NOT LOOKING CERTAIN!! THIS, BY THE WAY WAS BECAUSE A PLASTIC PLUG ABOVE THE RIGHT REAR WHEEL HAD BEEN OMITTED--WATER, SALT, SAND, AND WHATEVER UP INTO THE FENDER BODY. NEVER NOTICED TOHE OPEN HOLE!!
THE OTHER AREA THAT IS MUCH BETTER AND WAS REALLY MUCH EASIER: CUT ALL RUST AWAY AT THE REAR OF THE WHEEL WELL, THEN START OVER. COATED ALL RAW METAL SURFACES THEN BUILT A BACK BONE WITH ACE HARDWARE BRASS SHEET PIECES. THEN BONDO, OF COURSE. SEAL EVERY EDGE SOMOISTURE CAN'T BACK IN AND TRASH YOUR WORK.
IN MOST AREAS, CHOP IT OUT THEN CLEAN METAL IS MUCH EASIER. ONCE YOU START GETTING SOME NEW METAL BACK IN PLACE, YOU'LL KNOW YOU'RE DOING IT THE RIGHT WAY!!
