Dome/Map light wiring schematic?
domoarigato
Hey guys,
Is there a wiring diagram anywhere for the 07-14 tahoes dome/map lights?
Currently, when I open / close the doors, all my dome lights turn on with the exception of the drivers side map light in the front.
However if I try to actuate the driver side dome light, it works fine... So that also rules out the bulb itself being bad.
I assume since there is dual functionality (dome on when doors open and dome on when light switch is activated) there are two grounds somewhere that I should probably check.
If there is a wiring schematic somewhere I would greatly appreciate it, if not I will probably invest in a Bentley manual or something similar to help / share info with the community.
Thanks!
D
domoarigato
Update: removed the overhead panel this weekend, turns out the switch to the dome light was just loose... guess it was on the side where it received ground from the door switch.
problem solved :)
tbird71
