NHTSA opens preliminary probe into more than 870,000 GM vehicles
jfoj
Kind of thinking the 2017 engine with over 100k suffering from a failed rod bearing could be due to Low Speed Pre Ignition (LSPI)?? LSPI in conjunction with 0W20 oil probably is not an ideal situation. Adding a catch can to also capture and remove additional oil vapors that end up being added back to the combustion airflow that could also help reduce LSPI.
Things to consider
NT1978
I got a brand new Tahoe in January, 2024, and in November I had a catastrophic engine event with the 5.3L. I got stalled with a child in the middle of a busy intersection and it took a month for them to get my engine replaced. The service tech believes the fuel management system broke down starving the engine of fuel and causing a piston to break off.
I have owned vehicles for nearly 30 years and never had anything close to this happening. Is this recall for the 5.3 and 6.2?
FWIW it's not a recall. Might never be.
jfoj
Interesting info from King Bearing linked below. If you somewhat read between the lines, there are a few things that appear to stand out.
1. Hot Short - Might be a bit far fetched on these engine under daily driving conditions, but think about it of you understand a Hot Short condition. This has been found associated with NASCAR and other racing series where the engine has been shut down when very hot due to a red light/flag condition to stop the cars mid race for some reason and the bearings heat soak and the material becomes soft. Then restarting the engine with the bearings hot and possibly soft can cause either immediate damage or partial damage that can be seen when the engine is torn down after the race.
While this comparison is not as severe, think about all the Auto Stop/Start conditions and the possibility of Hot Short conditions or partial Hot Short condition that could possibly occur. Or continually having the Stop/Start function active how this could impact bearings with partially dry starting conditions. Add the 0W20 oil that may not hold a film on the bearing surfaces so well when hot. The fact that the vane style oil pumps loose their prime quickly, This may cause bearing degradation over time and not cause an immediate failure. Turning off or disabling the Auto Stop/Start feature may help this condition? Is the Stop/Start feature a contributor, who knows for sure? Maybe it is a problem if the bearings start to fatigue as outlined below?
2. Bearing Fatigue - Could be due to Detonation/Low Speed Pre Ignition, High Torque/Low RPM operation which is pretty typical with these engine designs these days along with the 0W20 engine oil. Also keep in mind that there could be one or more fuel injectors that may not operate properly that could cause a LSPI condition in one or just a few cylinders. I do not think the LSPI really manifests itself into a misfire condition or knock condition that the ECU can pick up on. Wonder if the DFM could also put more stress and fatigue on bearings when dropping cylinders out and making the operational cylinder(s) work a bit harder for short periods of time.
Adding in fuel dilution of the oil, water contamination, extended oil changes all do not help the oil situation. Installation of of catch can can help reduce some of this problem as well.
Curious if the Trailer Towing packages help with extra cooling of the engine and/or engine oil may help prolong the engine life and/or reduce some of these premature failures?
At the end if the day, the majority of these engine failures can be classified as oil related failures in some form or another. The 6.2l has a 2 stage oil pump that may or may not be contributing to its early demise. If I had my way and I may look into it, forcing the oil pump into the higher pressure stage might be a good thing. Either damage due to improper lubrication, not enough oil in the right place at the right time, contaminated oil, or some form of bearing overloading.
While GM claimed at one point that oversized lifter bores were the cause of some failures, not sure if this was more a cause of lifter failures, bearing failures or both. I wonder how oversized the lifter bores actually were? Enough to starve the main and rod bearings of oil? The oiling path on these engines is not ideal, but it seems back as far as the 6.0l non AFM/DFM engines had a similar oil path without the level of problems. Even the current 5.3l does not seem to have the level of problems the 6.2l is having, only obvious this between these engines is the 2 stage oil pump that I have found.
Just a few thoughts.
jfoj
The 5.3 has the 2 stage oil pump also.
Well I am not seeing this as the case. Maybe I have wrong, outdated information, but what I have been able to find does not confirm this.
Both engines have a variable displacement vane style oil pump, but the 6.2l appears to have a 2 stage oil flow control solenoid.
I am having hard time finding the actual solenoid as a part number, but there are different part numbers for the oil pumps, not sure if this is due to the flow control solenoid or not?
The wiring pigtail for the oil flow control solenoid only shows up for the 6.2l, not the L84 5.3l, but does appear to fit the L83 5.3l engine
And for the L84 5.3l engine the oil pump part number is listed as GM Part # 12733671 and any real pictures I have found do not include the oil pump flow solenoid like the 6.2l.
For the L87 6.2l engine, the oil pump part number is listed as GM Part# 12733670
The earlier 5.3l L83 engines may have had a 2 stage oil pump, but I am not finding this on the current generation L84 engines.
I may be in fact wrong, but I have put a lot of time in researching this and maybe I missed something?
I am sure the crowd will correct me if I am wrong.
I have my 20 years tied up in the 6.0l, not spent much time with the newer 5.3l and 6.2l, just starting to get a grasp on these.
CaliCrusin
