door lock questions
Tbruz
Windham NH
Door locks on a 1997 two door stopped working from inside the truck.
Not working from drivers side, passenger side or from rear barn doors; there is no sound at all when activating these door lock buttons.
If I lock or unlock from the key fob remote; everything works fine, all doors lock and unlock properly.
Because of this I assume the fuse is good and the actuators are just not getting power from the door switches
Any ideas; trouble shooting tips or schematics appreciated.
Thanks
Tbruz
SunlitComet
OBS Jedi-Do Good
unknown at this time.
switches also activate the relay that fob would so try fuse 13 it provides power to switches when key-less entry is installed.
T
Tbruz
Windham NH
Fuse 13
OK fuse 13(25A) is blown; what else fuctions off of that fuse?
Thanks
Tbruz
SunlitComet
OBS Jedi-Do Good
If installed cigar lighter, pwr lumbar seat, Power amplifier, Rear lift glass and door lock system partially.
T
Tbruz
Windham NH
Fixed!
Thanks for the leads!
Lumbar wire on drivers side was messed up and grounding out to seat frame.
A few wraps of black tape around the wire and fuse 13 doesn't blow anymore.
Tony
kainerbk
