Door speakers
PoloGreen
Saint Louis, MO
How hard is it to replace front and back door speakers in a 02 Yukon? Is the front door 6.5 components and the back just 6.5?
DarkTahoe00
IN
There not hard at all to change. Yes the fronts are knda like components but there's no network crossovers,and yes the rears are just 6.5's.
titanium02
w7's or bust.
Norfolk, VA / ATL
I actually had to modify the plastic housing the speaker sits in.. the bolts were not lining up or something (honestly forget the problem) but all it took was a dremel, some glue, and about 30 minutes of thinking. I had to cut the ring from the base and reverse mount it. I know that all sounds really confusing but it was like 3 years ago.. just trying to pull from memory what was wrong and how I fixed it.
Actually did a beautiful install.. looked professional ;) Fit like a glove. I don't know if others had this issue, or if it was just the speakers I was using. (Boston Acoustics Coaxles)
oreowizard98
Monroe NC
Why do some rear doors have grills molded into the door panel and others have actual mesh grills? Is it the difference in LS and LT trim?
Copper&Black
If you are never going to put an Amp in then the lower end alpine or infinity reference components will be enough to handle the stock power. Kappa perfects are 100 watts rms so the 45 or so your head unit is putting out might not be enough to justify the cost. If you are going to add an amp then I say Kappa Perfect Components like Anthony says....
gmdehart
