Double cardan with 6" rcx
Frisbie
From northern michigan, live all over the place
Getting ready to put the 6" rcx on my 99. I know I need the front driveshaft I was just curious if anyone knows if you can just add the double cardan joint to the stock shaft or if the whole shaft is required. Also if I should look into having mine altered to what i need or just order it for 450.00. If it isn't significantly cheaper I will just order it. And does anyone run without the rear sway bar I want the better articulation on the trails but how bad will it drive on the road? Thanks for any recommendations
SunlitComet
OBS Jedi-Do Good
unknown at this time.
if you meet the same spec you can build something but why bother with the effort when someone has done all the design and proofing work already for a driveshaft.
F
Frisbie
That's what I decided I was just curious as to the joint. If it was just something I could buy and swap my u joint out with and have the same product. I just bought a new front drive shaft a couple months ago and new u joints but that's ok lol.
audley71
