Frisbie
- Joined
- Apr 2, 2013
- Posts
- 13
- Reaction score
- 0
Getting ready to put the 6" rcx on my 99. I know I need the front driveshaft I was just curious if anyone knows if you can just add the double cardan joint to the stock shaft or if the whole shaft is required. Also if I should look into having mine altered to what i need or just order it for 450.00. If it isn't significantly cheaper I will just order it. And does anyone run without the rear sway bar I want the better articulation on the trails but how bad will it drive on the road? Thanks for any recommendations
