double din cage in 2000 yukon
benztrk
Central FL.
Ok, I've read the sticky post on fitting a d/d in a non-d/d dash, and decided to go with a newer cage first. I've bought a 2003 (i believe) double din cage, and am going to retro fit it into my 2000. Other than changing the cage, what else will need to be done? I have the install kit for my 2000, but I assume I'll need yo get one for 03 or newer now right? What about HVAC controls...... saw soomrthing about moving them down a touch. Any insight on how to do this, or is it neccessary. Also what about dash bezel, easier to trim mine, or buy a 2003 or newer bezel? How is the fit on the newer bezel to my dash? thanks for the help. Pics would be great if anyone has some of this install.
B
benztrk
Central FL.
It says that the 03 and newer dash doesn't fit perfect. Anyone know why, and what part this isn't right about it? Anyone have pics.....
Nickleahy23
Portage/Menomonie, WI
the 03+ bezel blocks the power outlets a little bit and messes up the door opening and closing on that, as well as it fitting goofy since the openings arnt the same size for the hvac area
B
benztrk
Central FL.
nickleahy, I see in your dign yuo have a double din, do you have any pics? And how did you do your bezel, cut it or use 03+?
Venator
