Double Din
blackcoffee
O.G. Black.
Don't use the plastic front cover they give you, make your own. The rest is really nice.
poke
I'm currently working on installing a 2DIN using the kit off of this site, lots of work indeed.
If there is one thing I would caution you on is to perhaps go and get smaller screws for the HVAC, I installed the ones supplied and now I am searching wreckers trying to find a "new to me" HVAC.
D-Block
Calabasas, CA
i'm currently working on installing a 2din using the kit off of this site, lots of work indeed.
If there is one thing i would caution you on is to perhaps go and get smaller screws for the hvac, i installed the ones supplied and now i am searching wreckers trying to find a "new to me" hvac.
doh!
Crispy
Slate Belt, PA
If you dont mind using a dremel, you can do it yourself. You would have to fab up bracketry (which is very simply for this application) and your dash bezel would be cut. I will try to locate a pic for you. Its honestly not the prettiest thing, but if you are good with your cuts and have some sand paper to finish the edges, its a cheaper alternative to the above mentioned kit.
Rachawn213
