Dreaded Rust..
89Suburban
Bull in the china shop
SE PA
Today a little short fiber glass putty. Next some seam sealer and paint.
I also have a picture of what the Denali trim covers
89548d0586b77d9a0ad250a639f742e1.jpg8fe1aa65ef14b103ac432e0e6440c7a1.jpgc87809cdce738577e511e64fca8c03cd.jpg
Nice job! Is that welded in?? Any welding pics?
Nice, not much of the repair will be seen.
S
Sdp1234
Southeastern PA
Primer, light sanding, white base then seam sealer. Seam sealer didn’t go as well as I’d liked... I’ve also had problems caulking in the past
7219ab6a65d8c7097ee534614eeb54c1.jpg4b19ba52749b2d288dfe236981647f43.jpga2306e14a004eb006d15e99b9c6ae5e6.jpg
NoReverseYukon
NE Wisconsin
Having never applied seam sealer before, but when using silicone caulk if you spit on your finger before smoothing it, I know the caulk won't stick to your finger. Water won't work, but spit does.
S
Sdp1234
Southeastern PA
Almost done. I rushed the paint a bit so there is an area I have to fix. Looks like it’s time to put it back together. Some polishing blending and a peeled area to fix 2667759287264ad18b5427c199610a8f.jpg
How do I remove this plastic piece to paint under it?
I have never removed one but I’d bet it’s held with high bond tape so there’s no holes through the metal which would create a place for rust to start since that’s a wet location.
S
Sdp1234
Southeastern PA
I’m marking this off as finished even though I may come back and redo the paint just a bit. It’s a 15 year old truck and the repair looks good from 6 feet
jlmorrow
