Jobi-Wan Kenobi
- Joined
- Aug 27, 2022
- Posts
- 213
- Reaction score
- 295
So I have this odd noise that shows up when I'm driving with four wheel drive engaged. Really it shows up almost as soon as the vehicle starts moving. I had thought it was coming from my front axle assembly so I swapped in a replacement but there was no change. It's not tire related. It doesn't change with the type of road surface I'm on. Is it possible that one of the front hubs would be loaded in some weird way that would cause this? I have no hub noise otherwise when I'm in two wheel drive.
I had gotten to wondering about the transfer case here too. After I started looking into transfer case issues I found the issue for the worn pin hole. As of right now though mine is dry and not leaking. Would there be any other symptoms that can be observed before a leak would start?
