Driver Information Center
ThrillWill901
Independence MS
My bad bro. A lot going on lately. Well it wasn't exactly real easy in the beginning because I never had the factory pigtail that plugs into it. So what I did was I ordered a radio harness kit. I'll have to find the # for it. It came with 2 factory style plugs. Large one I'm using for gauge cluster testing cuz it fits the cluster assembly, the small pigtail fits the DIC. BUT!!! The wire pinouts were wrong on it! So I had to hunt down the correct connector wire pinout chart. Luckily my brother had it on his computer at work. I never plugged it in one time before I checked the wiring about 5 times over to be sure. You def don't want 12volts running into your Class 2 Serial Data! Let me know if you need anything
Thanks a lot. Got one ordered now. Will reach back out if I need anything.
ybndino
This is the connector kit I got to use for it. Small one fits DIC, large one fits radio or the gauge cluster. Just have to re-pin them to workView attachment 396621
If you do actually get one and want to wire it up then I can send more pics and/or walk you thru it. If you can get it with the pigtail wiring still connected then that'll make it easier
would love to get pics picked one up off ebay for my 01 tahoe and want to put it in before i get my transmission back in
SavageWarrior13
