Driver power seat not working
Juicifer
Atlanta, GA
I'm about to pick up a '98 2-door and the owner says the only issue inside is the driver's power seat doesn't work. He's not sure if it's the motor or just a switch. I'm having it looked at this weekend, but does anyone have any experience with this?
Is it an expensive fix? If so, how easy is it to find and replace seats on these? There's gotta be plenty out there right?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the motors/seatrs are generally gotten from a junk yard. the switch usually from a dealer. is it all functions? if so you may just have a missing or broken circuit breaker on the i/p fuse block on the left side of dash. there should be two of them there.
Juicifer
Juicifer
Atlanta, GA
not sure, but i'll know after the dealer checks it out this week. thanks for the info!
does anyone know how much i should spend if i buy a seat from a local junk yard? and are there any tricks or shortcuts to removing/installing those front seats?
SunlitComet
OBS Jedi-Do Good
no more then $100is very likely. unplug connector from body and use 15mm sockets for bolts. they will need effort to remove and install.
witty_name
