Driver side power window switch/module
WickedGoat
Lebanon, MO
Having issues with the window switch/module on my 2004. Replaced the stock switch earlier this year because the windows wouldn’t go down all the time and when they did, it would be a pain to get them back up. The door locks started randomly trying to lock and unlock also.
I pulled it and replaced it with an Amazon part. After a couple of weeks it started acting up and half the functions wouldn’t work. Returned that, got a refund, and bought a Standard switch from O’reilly Auto Parts. Bad luck continued and warrantied that one out for another Standard and everything worked liked it should until this week. Some of the buttons are now very flimsy, the lights on the window lock and folding mirror buttons some times stay on with the key off and the mirrors move all the way down with the key fob.
What particular replacements have you guys had good luck with? I need a 15883319 which covers adjustable pedals, folding mirrors, etc., which is the 62 pin module. I found one GM part available but it is $365. I might be able to get it a little cheaper. Don’t know why this damn thing has to be so complicated.
Fless
Super Moderator
Elev 5,280
Are the ones you're buying programmed? I'm under the impression that they need to be programmed for the options, but I'm not sure if there's only one for your model year, and maybe they're already pre-programmed.
When I had my Tech 2 I updated (programmed) the calibration on my driver door module.
Galactic23
