Driver side window weird noise
Red Rider
So I have started noticing a weird noise coming from driver side window. It is like the noise when you click button to get window up and then it makes a few noises as the window stops at top of track then settles in a little. It is not clicking or squeaking. Seems to happen more when i hit a bump, but not every time.
at first i thought it was the switch that was stuck on up position and it kept creeping up, but i lightly touched switch and it does not seem to go up or down.
If i bring it a hair down, it stops doing it. Any ideas?
Rookie
Supporting Vendor
Elkhart, IN
I'd pull the door panel and check the tracks. I had another vehicle that did something similar and the track was loose. When I rolled the window down a hair it put more pressure on it relieving the noise. Tightened a couple bolts up and it was gone.
freedommotorsports.us
Phone: 260-444-7503
Email: [email protected]
08grey
Check if a bolt came loose. I had a track bolt loosen up on mine and it made it noisy.
patniven
