Driver Speaker Quit-Where to Start?
GMT800 SUV/Trucks
I recently got 4 new speakers, GM, from RA for my girl's 2002 TrailBlazer. Price was fair and sounded great. If you read all the info for that UQ3 speaker, it sounds like you should be ok: Should probably get that connector to be safe: https://www.rockauto.com/en/moreinfo.php?pk=945645&cc=1431230&pt=2616&jsn=1074&jsn=1074&jsn=1074
They did not have the GM connector but this aftermarket connector cross references to the 12101825 suggested connector
Fits Front Side Door; Mating Connector w/ Leads Use 12101825; Enhanced Speaker System (UQ3)
or Front Side Door; Mating Connector w/ Leads Use 12101825; 4 Speaker System (UQ5), Power SIDE WINDOWS MAY INCLUDE REMOTE KEYLESS ENTRY (5B5)
GMT800 SUV/Trucks
Also, from what I see, if it has 2 speakers and one is a separate tweeter, the second speaker number I gave you should be it.
GMT800 SUV/Trucks
Do you have just one or two speakers? If one speaker feeds the other with power to work, and the upstream speaker is bad, your scenario could be relevant. In the pics it looks like two separate speakers. How is yours set up?
YukonRog
YukonRog
Auburn, CA
I thought there was a small tweeter. I'll get back to you.
nonickatall
Germany
So I pulled the door panel and couldn't find any loose connections. Is there a fuse for that? What does the "dinger" have to do with everything? The wire umbilical seems okay too.
You can basically have three problems. (in descending probability) e
Either the output of your power amplifier or the radio is defective and there is no sound at all.
Or your wiring harness to the speaker has a problem. This often happens in the door area, where the wiring harness is regularly bent back and forth when the door is opened.
Or your speaker is deceased.
And as QR VietVet wrote, you can test harness and speakers with this Dinger, which I also didn't know that that runs through the left speaker...
YukonRog
YukonRog
Auburn, CA
So, yes it has a tweeter. Does the tweeter need to connected in order for the big speaker to work?
SLOGoing
