Drivers Heated Seat Problem
strussy
Q-town PA
Have a 01 Denali drivers seat worked fine one day and the next it stopped. Pass works fine. The switch lights up on high and low just no heat . checked all fuses and they are fine. hope its not the element,but i figured it would be the top or bottom not both heat pads. Any HELP would be great.
chauncey0337
MLT, WA
Yeah, seems weird they both go out at the same time. I'd check to see that all the plugs under the seat and inside the door panel are secure.
strussy
strussy
Q-town PA
from what i can see they all look plugged in, but maybe i'll have to take the seat out and check. cant see the switch being bad if it lights up on high and low . if anyone knows where the module is for it that would be helpful.
rnfernandez1968
