yes just be careful there is a little clip if you break it good luck finding that connector, I got lucky and my dealer parts guy found it only listed as "genuine gm connector" no part number listed anywhere.Can you just unplug these and spray and reinstall?
to the op when you hook up the tech2 and scan for DTC's the trouble code should point you right at the problem. mine was also a loose connection at the front right strut.
