Driver's seat controls are backwards sometimes
Dpounders
If my drivers seat is all the way back and I move the slide control forward to move the seat up it moves up about half the way then stops. It then doesn't respond for a few seconds. Then to get the seat to move the rest of the way forward I actually have to slide the control backwards. To move the seat back I have to slide the control forwards and it goes about half way back, stops again for a few seconds and normal operation resumes from there back. Has anyone had this happen or know what would cause this?
chauncey0337
MLT, WA
I just responded to your window problem thread. Now after reading this one, I think you have a BCM problem. I'm not 100% sure but you might need a reflash or reprogramming of the BCM. Hopefully, someone can confirm or object to this.
D
Dpounders
I had the dealer reprogram my drivers seat module after reading several posts with the same problem. Cost me a $100 but my seat works perfectly now. However my window problem still exists. Is the reprogramming that the dealer did the same as a bcm reprogramming or flash that you talked about or is that something different that I would have to pay again for?
chauncey0337
MLT, WA
I think it's different but don't quote me on that. Maybe you could run it across the dealer.
MynameisYeff
