Driver's window problem
missta
Nork, NJ
02 tahoe ls drivers window is not getting power. My girl was driving the hoe when i was away and the window got atuck down. She took it to a friend who got it back up. He said thw motor was going bad. I replaced the motor and regulator...window worked fine when tested. I put the panel back on and teated the window again....nothing...i double checked thw wiring and nothing. Picked up a switch from the junkyard...all windows work except the drivers. I dont even heara click. I know power is going to the switch but i cant figure out why the driver side does nothing.
missta
missta
Nork, NJ
Fixed problem...the connection to the motor wasn't good....once i secured the connection window works better than before
missta
missta
Nork, NJ
Ok so wi dow is bugging again....after 2 days of flawless operation the window is stuck halfway down
---------- Post added at 01:37 PM ---------- Previous post was at 01:33 PM ----------
i need help the temp is in The 20's here
JochenWoern
Sacramento, CA
Are you sure your switch is working properly?
missta
missta
Nork, NJ
Just took it all apart again. Found 2 things. Back portion of the window wasnt fully seated in the regulator and the extension from the motor to the window connector had a loose wire. I removed the extension and plugged switch directly to the motor. I also made sure the front and back of the window was fully seated in the regulator. Window is working fine with the exception of reversed switch operation. Down rolls the window up and vise versa. Now i have 1 touch window up, but i can live with that.
---------- Post added at 04:36 PM ---------- Previous post was at 04:31 PM ----------
Thanx for your help JochenWoern
travishunter2016
