mikeyss
My 09 Tahoe needs rear u joints. I would like to replace the driveshaft with an aluminum one. However, I don't know where to look for one, and I'm not sure if mine is different from other Tahoe's. Since mine has the L9H, it has the AXN 9.5" axle. I don't know if my driveshaft is any longer or shorter than other Tahoe's, or if my u joints are different. I don't think I can cross reference an Escalade or Yukon Denali because they use a different AWD t case, and they use the smaller AXP 8.6" axle. The only other GMT-900 SUV to have the AXN 9.5" axle are the 2WD Escalade and Denali, but those would have a longer driveshaft because of not having a t case. I wonder if one from a 15+ would work on mine, those were aluminum, and I don't think between the GMT-900 and the k2 much changed in the frame, but I may be wrong
