DRL fuse
Denali132
Banned
When you put in HIDs or LEDs do you pull the fuse so the DRLs won't turn on? If not do the HID or LED turn on as DRL but dimmer like the halogens? Just curious what to do when I install mine.
Thanks
BrianT
I would like to hear on this as well. I have tried to find fuses like in the previous model but come up with nothing. I had a 2011 Denali and it was a simple fix, just pull the right and left DRL fuses.
Denali132
Denali132
Banned
I did the same in my 07 Denali I pulled the DRL fuses out. It should be able to be done in the newer models as well I would think.
pro510
The LED's I have light up when DRL is in operation. I usually use side lights to turn them off. There is a harness which is supposed to turn off low beams and light up LED strip when DRL is active.
Sent from my SM-G930P using Tapatalk
BigBlueLB756
By Marion, MS
Think you're out of luck as far as pulling a fuse to kill the DRL's. They're now controlled by the BCM.
wfstewart
