Dropped the wife's ESV some more from 2/3 to 4/6
L
langsbr
Tony, it looks like the offset on my wheels is enough that I'm rubbing on the front fender well lips in the front. Can I roll the fenders using the old bat method, or is there a special trick on these trucks that works better?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Can you give me the wheel spec?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
OK is it just rubbing on the little inner lip part?
L
langsbr
Yeah I can see where it's rubbing the paint on the edge of the inside lip.
I just realized the fender is metal all the way up so I didn't know if the bat method would even work.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
You can bend that tab up. Now on that offset you can run more negative camber. Will eat tires more but next time 285 45 22
L
langsbr
I'm gonna see what can do to get some more clearance tomorrow.
If I run some negative camber, how bad will I eat tires? Are we talking 10,000 miles, or 3,000?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Go -1.25
You can bend that inner lip up also
Pacdad
