Drum brake adjustment
DallasTahoe
I need to adjust my rear 11in drum brakes, question is when going from behind the wheel, which direction do I move the star wheel with my screwdriver? Thanks
drakon543
If they aren't adjusting themselves you should take it apart clean everything up. Grease the adjuster and replace any parts that are too worn to move freely. When you change the rear pads i usually adjust them so the drum just slips on and spins freely. Then operate the ebrake a few times and it usually sets it right where they need to be.
DallasTahoe
DallasTahoe
Thanks I've already done all that I just need to fine tune a lil that's why I just need to know which direction to turn it
drakon543
Well i dont know what to tell ya i generally leave it at that because i have the memory equivalent of a fart in a tornado and im generally *** backwards when im turning something i cant see.
DallasTahoe
DallasTahoe
Lmao that's a new one! Thanks anyway man!
drakon543
Ya ill turn around set something on my tool box realize i still need that tool turn around again and have to search the drawers because i forgot what drawer i put it in.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
cant recall my self but to say what ever direction spreads them out on the left is the opposite direction for the right. i think the one on the right spread the shoes when the star teeth nearest the access hole were moved up and outward or clockwise when behind the screws axis looking to front of vehicle.
Gm_guy
