e-fan question
ForgottenKnight03
After installing 05+ fans in my 02 this evening using a nelsons harness and blackbear tune, I started my truck and noticed that with A/C on, only the passenger side fan was spinning in high speed. I turned off the A/C in the truck, and that same fan stayed on. The truck seemed to be right around 190* the whole time while at idel in the driveway for about 20 mins (and after a short cruze around the block) When I disconnected the pigtail on the nelson harness that controls the fans for a/c operation, both fans would kick on low shortly after. is this working correctly? Do I connect to the light green wire or the green with white stripe? Thanks!
slocaddy
sarasota fl
you may have tapped the wrong green wire. if i remember right the insrtuctions say to tap the "lighter of the two green wires" or whatever it said (think theres only two) witch i did and was why i was certain i did it right. i switched and wala! just try it.
slocaddy
sarasota fl
not much, put brakes on my truck last week-it stops now! didnt know you were on here
Dieseldr
