E-Fan Wire, Solder or Connectors?
Dantheman-2003
Placerville, Ca
Getting ready to install e-fans. The OEM wiring harness came out of my 05 Yukon. I cut it out cause I was in a hurry so I need to add some lengths of wire. The splices I’ve tied together and soldered instead of using splice connectors. Anyone see concern or issues with this method?
Thanks,
Dan
tom3
That's always my choice when possible. Some concern about the stiffening of the wire at the connections but unless it's really small wire size I don't see any problem, and a soldered connection won't corrode or come loose.
adriver
Don't take this personal, but your soldering needs some help. I wouldn't leave it like that. You can't get a shrink tube over it, and that looks horrible.
It looks like you tried the, "spread the strands, and intermingle" method. I would heat that back up and separate it and try again, or cut it off.
Tried to find a pic of what I think is the best way. If you cut lets say an inch off the end on both, then you overlap by a little more than half, make an X, and then twist together tight like the top. Then you can heat and add solder over top. (So even though you cut 1/2 off, and you don't completely overlap, it only ends up being about 3/4" exposed).
I've found unless I'm doing stuff on boards, I rarely even like soldering anymore, and only stuff that's between 12 and 16awg. Anything outside of that, I think a PROPER crimper does a better job. It's quicker, cleaner, and just as secure.
For smaller stuff, and hard to reach areas, if I really want a soldered connection, I use these self-solder shrink tubes:
Dantheman-2003
Dantheman-2003
Placerville, Ca
@adriver. Exactly the feedback I was looking for. Pretty terrible work. Big nasty booger welds. I ordered some Wego connectors and am going to redo all this. I want it to be clean. The PCM wires I soldered are X wrapped and cleanly tinned and shrink wrapped. So I will likely leave those alone.
Multnomah Falls
Yea, that pic example was not there when first posted the thread. That is ugly. What @adriver showed and said is the correct way. Then the heat shrink will not look like raggedy pregnant lump.
Gotta have a good mechanical connection first. If not using butt connectors I prefer the half overlap method here (link starts video at 6:19) that @adriver recommended:
