08LTZ
Can I mix e85 with regular gas? And is it better on mpg?
Its best not to mix E85 with normal fuels . . .
it serves no purpose ( except to think you're being green by utilizing natural resources for fuel and not using them for food - corn) to use E85--- you get less MPG and yes pay less per gallon, but you are also getting less MPG. When you comare cost and the unnescessary wear and tear on the engine by using E85, it's not economically worth it--- if i knew a used vehicle ran E85 regularly, i would flat out not by it.
Thats completly retarded. If its a flex vehical beein on the corn juice its entire life, you can bet that intake track and piston tops as as shiney and clean as the day they was assembled.
The vehical was designed with alcohol friendly components. These will outlast non flex fuel vehicals by a landslide.
Now I do agree if its a non flex vehical been run )Without a conversion) on E85 for a LONG time like 5 years or more then no I wouldnt buy it..
But. theres only 3 places that will be affected by E85 on todays LS based engines.. the Fuel pump and the 2 short rubber flex lines leading off the fuel tank and from frame rail to engine hardlines.
Maybe, just maybe injector seals might deteriate. but the parts are so insignificant..
Alcohol based fuels are worlds better than typical petromleum based... It just ****** the USA decided to go CORN based over SUGARCANE.
Im not 100% positive on the country, but its someone like cuba thats been running their vehicals soley on alcohol based fuels made from sugar cane for like 30 years....
The stuff is proven, it works..
American automakers just donot convert to high compression alcohol friendly engines to make up for its lack of legs (MPG vs petroleum based fuel), this is required to reap the rewards from a high octane slow burning fuel..
Think diesal fuel in gas motors... it just doesnt work right..
but put that same diesal fuel in a engine Designed to run it and BOOM! instant high MPG and insane power..
