Egr
jdawg901
memphis tn.
I think my egr vac solenoid is bad is there suppose to be a little vac. When the engin revs .what this solenoid do
haks310
Got LEDs?
SoCal
Disconnect the vacuum line going to it. Press the diaphragm upwards nd cover the vacuum out let with one of your fingers, the diaphragm should not move. If it does you need a new EGR.
Pretty much it lowers emissions and keeps you from getting ****** mileage.
961500
Is it 2012 yet?
Austin Texas
Haks I saw in the 2000-2006 section the egr block off is this something we can do on ours if we get the ecm retuned? Want long tubes for my 96 but none have the egr setup that I have seen.
haks310
Got LEDs?
SoCal
Pretty confident you can. A lot of the 80s-90s F-body and 'Vette guys seem to do it. Planning on deleting the 02 sensors also?
961500
Is it 2012 yet?
Austin Texas
Want to but Austin does the emission test so will have to see what I can get away with and what Justin can do with the tune and staying legal as far as the test shows. My main issue is I have the fast burn aluminum heads with d-port exhaust so I need to get those style headders from an LT1 but I want long tubes if im going to pay for new tubes.
gy_psi
