Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I want to upgrade to an electric fan and have read that people have used the Dorman 620-654, i would like to know if i can use this is my 2004 Yukon and what harness/wiring i would need and where i can get them. Thanks.
You will also need to have your PCM (engine computer) programmed to turn the electric fan function on. You can get that through Blackbear Tuning. They are on this site.
what ever you do make sure all the connections on the relays are tight or otherwise youll be melting the relay harnesses and relays left and right. I had to actually take the wires out the relay harnesses and plug them directly to the relays
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
