Screamin Eagle
St Charles, Missouri
Thought I saw on here once about converting to electric fan set up for the HP gain. Im assuming my 03/5.3/4wd/yuk will take a basic elec fan set up off another truck, ill need to run a signal wire to the fuse block and tell my ecu that its elec fans now.
Anyone have the straight info on this? in case you are curious, I'm going to be going to bigger alternator & double batteries for lights/siren emergency set up and want to be maxed on my engine without a rebuild. When I need to get somewhere i need to get there quick.
What truck/van to get the fans
what fuse slot?
do i need to run a new pcm wire (what pin)
i run hp tuners
thanks in advance for the help!!
sparky 843
