Electrical issues
carnut169
Hoping to find some assistance/ advice with the gremlins we've got in our Tahoe.
The battery light, "check coolant", "check charging system" on the display came on and the ac started blowing hot all at once. The voltage gauge was showing 17v (ish). We took it to a couple local shops that both said nope, go to the dealer. So we went to the dealership and they said the battery ground cable was bad (?) and that was the cause of a malifunction in every module. They replaced it ($300!!- for a ground cable, but thats another story) and everything worked great for a couple days, then bam, right back to the same issues- at 1st blowing cold just through the driver's side vents and now all hot.
It's also got a new Bosch battery (2 weeks and showing 12.5v after sitting overnight?), a 1 year old alternator (NAPA).
I should probably mention that the headlights flicker pretty badly.
After doing a lot of web searching it seems like it could be an alternator (bad internal voltage regulator), bad battery or ECM issue.
Since the battery & alt are still under warranty I have removed them and will attempt to return today. Fingers crossed. The whole reason we took it in was to avoid throwing parts at it until something worked! Oh well. Still likely cheaper to do that that pay the dealer rates.
In the mean-time my wife is driving my truck or sportscar and this is bad. I've got to get her tahoe fixed!
Denali0229
FL
I can't believe they charged you $300 for a ground cable. That's just ridiculous. Takes 15 minutes to cut the wire, crimp it, then install. Less than $20 in parts if you use 0 gauge.
Sent from my PC36100 using Tapatalk 2
C
carnut169
When the advisor called me he was sure it was the cable. I asked how the cable could go bad and asked if maybe the connections needed to be cleaned. He said, it's $80 (the part), it's way more than just a simple cable. The balance $220 was to diagnose and install. FWIW, it is a basic cable, with a battery terminal at one end, grounded to the block at the other and a smaller ground wire going somewhere else.
The whole thing pisses me off. They wanted to charge $200 more to install new belts- I did it in 10min for $30. They replaced a cracked CV boot and left grease all over the inside of the wheel and shock (I removed it and properly cleaned it last night). On top of that they mis-diagnosed the problem to begin with.
The whole bill was actually $616 for a new CV boot and battery ground cable. Then they want me to check extremely satisfied on a survey or they doc the advisor's pay (or so he says). Sorry. I'm extremely unsatisfied.
popo8
That ^ is exactly why we all have to spread the word not to go to stealerships unless its warranty...covered for a reason other than that or you have a "connection."
Sorry for that experience. FWIW my money is on a malfunctioning alternator.
C
carnut169
Installed new battery and alt- the truck is running well and issues are gone. No codes on ecu. We'll see if this is a long term or 2 day solution....
bottomline2000
Dallas, TX
I've had a ground cable melt from a bad alternator. Based on the high voltage I'm betting on bad voltage regulator and the ground cable being a symptom.
Like popo said. Dealer for warranty work only. Big rip and they still got it wrong.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
19DenaliUltimate
