Panda85
- Joined
- Dec 27, 2015
- Posts
- 12
- Reaction score
- 1
So due to my last failed post with the instrument cluster. I'm concerned that there is more to the electrical issue than just the cluster.
I had my cluster sent out to be remanned. When I got it back I installed it and to my surprise. Only the rpm gauge works, but that's just as far as gauges go. I now have a check engine light on (has always been on), battery light on, airbag light on, abs light on and some light that is a picture of a car and a master lock ( what ever that means). That back lights work also.
Too add on to those issues there's the intermittent issue of the cluster not always working at all not even the back lights, including the interior lights staying with out even hitting the light switch, the door locks and windows not working. Even with the remote it'll sound as if you unlocked it while the remote start is on doors don't unlock, but when I turn it off the remote works for both lock and unlock.
Has anyone encountered this? Could this be a grounding issue with the BCM or elsewhere?
Someone Please Help!!
