Electronic 4x4 bulb replacement?
Symba_The_Lyon
How do you take the plastic case off the back of the chip board where the 4x4 harness plugs in? This will be the last bulb replacement in my dash and my dash will be all lit up after 10+ years of all the bulbs be blown c: Thanks for the help!!!
Donnie Yukonie
Yates Caretaker
IIRC it just clips in place, However To replace those bulbs they have to be sauntered in place
Symba_The_Lyon
Symba_The_Lyon
I know that they need to be soldered in but i can get to the back of the chip bord, I have pulled out both of the clips up and tried to pull the bord out but the the little proungs that plug into the 4x4 wont come loose is there a trick in to getting them loose?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
sauntered past participle, past tense of saun·ter
Verb
Walk in a slow, relaxed manner, without hurry or effort.
---------- Post added at 05:17 PM ---------- Previous post was at 05:03 PM ----------
that is the trick. i believe they are an interference fit with the back case or the socket is molded around the pins. not bee able to get one separated myself yet.
Donnie Yukonie
Yates Caretaker
Verb
Auto correct Fail
CaptPat
