Electronic Flasher unit?
iddqd
San Francisco, Comifornia, USSA
Links please. I have not seen anything that makes your signals flash 3 times when you momentarily hit the T-signal switch on a NBS like the programming in the BCM does on the NNBS.
I can give you links, but unless you can read Russian, they are pointless :)
Copy paste this: вежливые поворотники in Google and check out the pictures
Not doing the Russian thing. I have seen a wiki article where you can BUILD a “one touch turn signal “ module which is very involved and requires a breadboard and a dozen electronic components which then connects to 8 vehicle wires but that’s not what the OP asked for nor what most of us would be willing to do. You said there are aftermarket units. Are you saying they’re only available in Russia? Yeah uh huh. I don’t see the point of your post.
I am planning to order one for myself. I can order an extra one, if ou are committing to it
I’m not committing to anything, not even interested in doing this. I’m trying to help the OP which is what you should be doing if you’re posting here.
D
DrScottSmith
Thanks all - I did not realize that the turn signals went thru the BCM on the NBS trucks. I’ll get under there at some point and take a look.
thank you all again -
-scott
iddqd
-scott
on NNBS trucks. On NSB trucks (GMT840 platform) the flasher module (or relay really) is on the driver side right behind IP fuse block
07CLASSIC
