emblem painting
95escahoe
good afternoon, I have the 99-00 Denali conversion on my 95 Tahoe and I picked up the GMC letters for the grille I want to paint them black, whats the best way to go about doing this can you just paint them with or you gotta sand them too, and whats the best paint to use on them I am thinking some kinda spray paint that is safe to use on plastic I just want to paint them black to match the blacked out theme for the truck, thanks for the help
chauncey0337
MLT, WA
You can plasti dip it. Easy clean and removable. Or sand it with 600 grit, apply adhesion promoter(optional), base coat(2-3 light coats), then clear(also optional). Some people do it different ways- more coats, higher grit sandpaper. This is just one way and should suffice for emblems. You can use duplicolor or krylon fusion, both work well.
pickegs
