Emblem swap front and rear 2018 Yukon
irod87
I can't find a clear answer. I want to swap the front and rear GMC emblems to a black version. Can this be done without removing the front grill? I read somewhere that the rear is just glued on. Is that true?
2018 Yukon SLT
16yukondenali
I know the rear is just glued on. I just de-badged the rear GMC and YUKON emblems. Use a heat gun and a piece of fishing string to go behind the emblem to separate it from the cover. You can use a 3M eraser wheel to remove the residue or your fingernail and some goof off worked for me.
STORMIN08
agreed, generally there are studs holding the front on.
replacements with just use adhesive. rears are adhesive.
a-reem
