YukonJak
- Joined
- Oct 8, 2014
- Posts
- 13
- Reaction score
- 1
Over the weekend I installed Emergency response lighting in my Denali.
Since my job requires that I respond to all hazards of Emergency Management. Behind the grill I installed a 26" aluminum flat bar just below the hood release mount and place 4 Red/Blue strobe lights across the bar attached to the aluminum bar. At the rear across the top of the window, I added two more R/B strobes to shine out through the back window. In Each corner I installed in the light housings a White strobe the catches the reflector to bounce the light both to the front and rear and to the sides.
Next project to finish are to install the lights to better enhance side lighting.
And install the second deep cycle battery to handle the load.
What does GM use as an Isolator to separate the batteries?
Or does anyone have an option idea for the isolator?
