Tom Joad
French V8 lover.
Hi,
I'm pissed off with this mess. REally If i didn't need the money I would burn it down to the ground.
I've installed a Pioneer AVH-X2500BT in place of the OEM 6 disc player using a GMOS-04.
First the GMOS has a failure and doesn't give constant 12V. I had to run a wire from the battery directly to the universal plug of the Head Unit.
I have sound level issue : the volume goes up from 0 to 40.
FM radios are ok, but with USB, even at vol.36 it's too low for me when driving on the highway at 80mph.
When the USB is read at level 36 it's saturated. Bass are awfull...
The bose system did not have this issue...
This would be a small problem if alone. But the fact are I can't let my Tahoe in the parking lot from friday evening to monday morning without having to plus another battery to start it. 2 full days unused and the battery is empty.
This is a new battery I bought last week of december, 550 EN, 68Ah. Can't go bigger : not enough room there.
I'm thinking of removing the GMOS-04, the Bose amplifier (so long for the good sound) and the bose speakers and replacing everything with aftermarket compatible stuff.
I'd like to hear your stories about similar issues you had.
