Engine bogs
SnowDrifter
Washington. The starbucks side not the desert side
ticking with load when cold...although not likely entirely responsible for your symptoms, it sounds like an exhaust leak. Check exhaust manifod bolts. Probably a few broken like the rest of us
Depends on the nature of the leak. One significant enough to inhale oxygen from the outside atmosphere and throw off the a/f the oxygen sensor sensor would cause some issues
Does your fuel cap hiss when you crack it loose after driving for a little while?
sdhouseofwax13
