Engine code P0449
Fink117
07 suburban
Ok I already replaced the vent solenoid. Tested the plug for 12 volts which I have. I want to pull the PCM plug from the computer to test the white wire for Continuity but don't know which plug it is. After I clear the CEL 2 seconds later it's back again, I'm thinking I have a break in the control wire keeping power to the vent all the time.
Fink117
Fink117
I jumped the plug with a test light and the CEL will stay out. The test light also remains unlit which is correct. I got another new vent solenoid thinking that my new one was just a fluke bad one but the light came right on again. I also checked the connection from my white wire on the vent valve to the computer and it's intact and partially replaced. Not sure where to go from here. Purge valve behind the the alternator is fine too
khaleej
P0449- Evap Vent Solenoid Control Circuit
Red/White Is the Power B+
Wht is the Ground from the ECM
C1 Black Connector At the PCM --Pin 61 White
Check for a direct continuity.
And Let me know what happens.
Fink117
Fink117
Already did that its a solid connection
khaleej
You mean there is continuity.
So is there any ground present at the circuit . DO you have a tech 2.
If you have a tech2 then check if the vent clicks
Check For a Short To ground. the White one.
Might be shorted.
If Circuit is Ok Then I am afraid that it might be the ECM.
Do you have any Fuel Filling Problem .
If so there is a bulletin.
Waiting for your reply
Fink117
Fink117
It turned out to be that the pins on the stock harness were tested with a multimeter and the contacts of my new solenoid weren't touching. Lights off I'm good
khaleej
Bravoooo. It was the last thing to come in my mind.. Well done.
Btw i just tuned a vehicle with this same code a couple of hours ago...
Rubeng0315
