Hey guys,
I've got a problem with my new to me '03 Z71 with the 5.3L Flex Fuel motor. I believe the fuel pressure regulator has gone bad and I just wanted to pass it by you folks who are more knowledgeable than I. First of all I found that gas was shooting out the seal between the fuel rail housing and the regulator. I played with the O ring placement and inserted it carefully and no leaks, but it doesn't want to start. It cranks fine, just won't catch although it acts like it wants to.
I have limited tools and I would have liked to be able to check the fuel pressure but don't have a gauge. So I ordered a new AC Delco pressure regulator last night off of Amazon (50% cheaper than local parts stores) and I'll install it Wednesday night.
So am I going down the right road with this? Anything else I can check? Oh I have checked for spark and it does have it.
Thanks for any help!
Here's some pics if it helps to look at my setup:
Jeff
Jeff
