engine knock no oil pressure need help asap please
R
rayninglead
Michigan
A good friend of mine has a lt1 that he would sell me for dirt cheap runs great how compatible is that engine? Could I use the block?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Negative ghostrider. Rotating assembly for the most part but not everything. Not to mention that the block and exterior parts are a no go.
sgtpoliteness
Do you guys have pick n pull yards where you are? The ones here in Denver only charge like $200 for a long block.
sgtpoliteness
I'm asking because you don't need a complete engine, you only really need a short block, right? Where do you live?
R
rayninglead
Michigan
R
rayninglead
Michigan
I meant what comes with the gasket kit? I know it will all swap over from my old motor I should only need master gasket kit and head bolts correct? I know someone posted a short block before but this one is way less
Danl007
