Engine Noise At idle - Video
savagebasher
Any idea what the higher pitch noise is and why the engine is cycling like that? Belt? Or?
savagebasher
savagebasher
Well is in Jan in MN so I would assume AC is not on.. haha.. I will check though.
HiHoeSilver
Away!
Chicago
You don't have to have the AC on for the auto climate control to decide to run the compressor. You will notice in auto, the snowflake icon will come on and off on its own.
sounds to me like the a/c compressor is taking a dump, it sounds bad when not engaged and then is creating friction on the belt when engaged., a quick check to verify would be to take off the a/c belt start it up and I bet it sounds totally different. just take a 3/8" ratchet crawl underneath reach up to the a/c belt tensioner stick the ratchet in the center of the tensioner and pull this will release the belt and you can just leave it hanging there for the test. wont hurt anything to do this.
Faro
