Engine Oil Level Sensor
UNCLETONY
Working on an 04 Denali. "Check oil level" message displays on startup then goes away.
Checked connections on oil level sensor on side of pan and everything seems good. So I am thinking it is the sensor itself.
I tried searching but can't find it anywhere. Anyone have a part # for the oil level sensor. Thanks
Physh1
You didn't mention if you checked the oil level...? That message displays for me when the oil level is just above the low hash mark on the dipstick.
Cameron
livingez_123
Sandy, OR
I was going to say that earlier, but isn't that the first thing you would do? Buy some of the questions on this forum, some of the people don't seem that bright.
U
UNCLETONY
Oil level is correct. Truck has been doing this before and after the last oil change I did on it.
Physh1
I did a quick search on rock auto...
Came up with lotsa part numbers...Alternate/OEM Part Number(s): 12579983, 12579985, 12603782, 19603782, 22568381, 24501416, 24507190, SU1316
AIRTEX / WELLS Part # 5S3003 is the one they sell & it looks like it's a pretty standard part across the GM line...$15
Cameron
U
UNCLETONY
Thanks for the part #! I tried finding it on gmpartsdirect and another gm parts supplier and was coming up with nothing.
Physh1
No prob...good luck! Hope it fixes your problem...
Cameron
