Engine over heating with AC on at low speeds
afpj
You put NON Dexcool anitfreeze in? I cannot recall specific posts but that alone might lead to bad things happening...perhaps it was in the long term but I thought I read Dexcool had certain chemicals in it that others didn't for these GM's. Curious as to why you didn't use dexcool?
BRUTUS_T_HOG
Did you put straight antifreeze or was it 50/50 premix? Using pure antifreeze will cause overheating.
When its running hot is the fan moving a lot of air through the radiator and is it hot air? It should be moving a lot of hot air. New does not mean good when it comes to your fan clutch.
Another thing, if you increase the engine RPM's a little does it cool down?
---------- Post added at 11:41 PM ---------- Previous post was at 11:37 PM ----------
Dex-cool vehicles can safely be converted back, though I personally like to use what the manufacturer designed their product to use.
Dex-cool is silicate and phosphate free to prolong water pump seal life, reduce corrosion, and be more compatible with the increasing amount of aluminum parts used in cooling systems.
92__silverado
50/50 mix
The fan seems to be moving a lot of hot air when its hot.
Today after running the AC and getting up to about 220 i turned off the AC and increased RPM. The temp never went down, after about 5 minutes, I turned the heat on.
If finally started to drop after 4 or 5 minutes. it dropped to about 210, then hung there, then dropped below 210. When the temp drops it isn't gradual. it drops in 5-10 degree increments it seems, for what that is worth.
Yes flushed out all the dexcool and changed over to regular green.
BRUTUS_T_HOG
I just went back and read that you are seeing 90 degree days. With it being 90 ambient temperature it sounds normal to be seeing 210-220.
190-210 is normal op. temp and running the AC puts more load on the system because it adds heat to the air traveling across the radiator
92__silverado
190-210 might be normal, but 230-250 is not. Putting a radiator in since everything else has been replaced.
BRUTUS_T_HOG
Yeah 250 is way too high I would say 230 MAX.
Being 90 outside though puts a heavy load on the cooling system. I think you probably do have a partially plugged radiator. Let us know how it goes
Yukonboy2014
Idling in 110* heat today (no Joke--South Tx), AC on full, my '01 Yukon did creep up to 220-230 before I realized it was escalating, so I revved the motor up a bit to get some air moving over the radiator. I guess the mechanical fan just can't move enough air at 500 rpm idle to keep up with the heat load. I'm looking around to fashion a sort of high-idle switch to keep air moving when idling in the heat.
Krbobby
