EddieC
- Joined
- Aug 9, 2014
- Posts
- 698
- Reaction score
- 552
Yes, they changed the bearings. How is the VSES reluctor changed if needed?The wiring for the ABS wiring as it attaches to the axle could have been damaged, I accidentally stretched mine but caught it before breaking them once when I dropped the axle.
They may have damaged the VSES reluctor inside the axle tube if they replaced a bearing on that side.
The simplest issues may be that the connector at the axle was not put on right, check that first, it's cheapest!
My error does states an issue with the "speed sensor circuit" so I guess the easist first step is to swap out the sensor and wire assembly.
