My check engine light came on the other day and I got these codes: Evaporative Vent control circuit P0446, Left wheel speed sensor C0035. Does anyone know what these codes mean and how easy of a fix they might be? 07 Tahoe LS SSV package.
The PO446 can be either the gas cap is loose/bad, etc or the solenoid behind the throttle body under the plastic engine cover needs replaced. I've got the same problem right now. I'm going to buy both.
---------- Post added at 12:36 PM ---------- Previous post was at 12:34 PM ----------
The wheel sensor might be bad or needs recalibrated for the other code.
