Escalade Auto/Express Up Windows
PatDTN
I would love to add express up to my '09 LTZ. Do you have a list of part numbers for what I'd need? I never sit in the back. Do I even have one touch down there?
Thanks. I noticed you had a bit of a rough start on this thread. Funny I might have posted exactly the same way.
91RS
GA
The switches are: 20877337 and 20835556. I bought new ones on eBay but they have to be programmed if they're new. I bought used regulators and front door harnesses off eBay from salvage yards. The harnesses are discontinued. I would have bought new regulators had I not been planning on doing both trucks all along. As I said in my last post, you will lose the heated and ventilated seat functionality with the Escalade switches because those switches are not on the doors in the Escalade. I'm hopeful that White Auto and Media can make a custom program to make it work in the Yukon and I'm willing to spend a little more money to get this all working but they're so busy.
PatDTN
Thanks. One of the things I bought my Tahoe for is the air conditioned seats. Hm.
91RS
GA
I’m not giving up my ventilated seats either. I’m really hoping that a custom program will be the solution and that it won’t cost too much. I’m sure I’ll lose my ass if I try and resell these parts so I think I’m going to hang onto them and see if they can help when they’re less busy or maybe there’s another company I don’t know about that offers similar services. The good thing for me is that this worked out just fine in my Escalade and I only drive the Yukon on the weekends.
petethepug
Michael
SoCal
2012, 13 & 14 Chevy trucks have express down windows. I believe 2014 has up and down. If you can find a match to your truck to a later model 1500, 2500 or 3500 truck they components are already programed if the part is used and if you're lucky it'll be a complete drop into your truck.
adventurenali92
Big Bear Lake, ca
Wouldn’t the 2014 pickup truck be a K2 platform? In which case the switches AND programming would be entirely different? I thought that the K2 started with the pickups in 2014 and the SUVs started the K2 platform in 2015?
petethepug
Michael
SoCal
I'll guess he has full power mirrors and dug through some old threads and saw he was working on a 2012. Again guessing he's working with part # 20835553.
This links shows huge cross compatibility up to 2014 (1500, 2500, 3500). If this is what he is using in his truck already, hypothetically, if he pulled a switch pack from a (used) 2014 3/4 or 1 ton that is known to have express up / down windows, it'd be plug and play because the switch pack is already programed for the feature.
I just looked through some of the other truck forums and saw that some truck owners had express up and/or down functions in their 2013-2016 Silverado. I figured that GM liked to reuse the same parts and got lucky is this is the switch pack he's already using.
2007-2019 GM Window Switch (MAY REQUIRE DEALER PROGRAMMING AT INSTALLATION) 20835553 | GMPartsDirect.com
91RS
GA
I’ve never seen a 12 or 13 that had auto up except an Escalade. The window regulator part number only shows to fit Escalade as well. The 14 is indeed the K2 body style and everything is different, plus the pickups only got the auto up on the driver side.
petethepug
Michael
SoCal
Owners of 14-19 Silverado and Sierra acknowledge they have express down on all 4 windows and up on the driver’s.
The link I posted in the last post shows that part is x compatible with 07 to 19 1500 & 2500 Yukon.
Again, I’m not sure what switch pack is in your truck. I’m assuming it’s a ‘12 Tahoe or Yukon.
If I still had 08 Denali XL I’d purchase a used 14-19 switch pack from a Silverado and Sierra in a heartbeat knowing it was programmed from the factory for express down on all 4 windows and up on the driver’s. If it worked as a drop in solution, great. If not, return it back to the seller with a candy bar in the package.
https://www.gm-trucks.com/forums/topic/214206-window-auto-up-feature/
“I noticed the driver window switch (2018 Sierra SLT) has all auto down and driver auto up with the two click feature on the window button. I notice only the driver has that double click on the way up.”
Abelton
